@EdStainless
According to ASM Metals Handbook Volume 13 C
Alloy 600 (N06600) is used as an alternate to alloy 200 (N02200) in caustic environments, when the latter is not of sufficient strength. Alloy 600 was also used extensively in nuclear steam generators, until superseded by alloy 690 (N06690), which was found to be considerably more resistant to stress-corrosion cracking in pure water, at high temperatures.
Also, I read MTI MS-6 previously as below:
Commercially pure nickel, alloy 200 (N02200) and alloy 201 (N02201) are the best materials for resisting corrosion and stress corrosion cracking in caustic environments. Alloy 400 (N04400) and alloy 600 (N06600) also have excellent stress corrosion resistance. These alloys can however suffer from caustic stress corrosion cracking at caustic concentrations above 70% at temperatures above 290°C (550°F).
Since concentration in my case is 50% and temp. less than 290C, from two above clauses I've concluded Alloy 690 works. But, another question arises what general corrosion rate would be? Please let me know if you have any thought.
@metengr
Do you mean failure due to general corrosion or stress corrosion cracking or caustic corrosion cracking?
