Rakesh2560
I have to select material for isolating the boiler from stack (two boilers are connected to same stack we need one for maintenance) . I am not sure for which material to use for blind ?
Our planner has offered a283 gr8 c which is a structural steel grade when I referred as me sec 2 part d it prohibits it's use in sec1 design hence I cannot use it in boiler .second option is a516gr60 which is a better grade can I use it for design or need any specific material ?
Thanks in advance for all extended help
