Material Files
  • Thread starter Thread starter saspinall
  • Start date Start date
S
saspinall
Guest
[No message]
No idead why nothing entered
Want to start using material files in Pro/E Wildfire and Mechanica for structure and thermal analysis, but what units are entered into the material files as Mechanica fires up into default units presumably. We currently use imperial units for usa work.
Thanks Stuart
Stuart,
The proE default units are mix match an will give you the incorrect results. My advice to you is to change the units to IPS from the setup menu. Then switch to MECHANICA and assign the materials properties by using the default provided by MECHANICA ( Not from ProE) or create a new one. If you create a new one you could always mix match units and let MECHANICA do the conversion. The new material property can be saved for later use in other models. If you follow these steps the chances of error will be minimized.
Luis
[No message]
