Guest
Hey,
I'm looking for someone who's come across this problem before:
The design of a lightweight flexure hinge.
Basically, I am trying to design a lightweight flexure hinge, (like those found on plastic shampoo bottle lids) I know already that I should look for materials which have a high specific strength to stiffness ratio.
The hinge should bend to a known radius - the strength constraint. It should also offer a resistance of an exact amount - the stiffness constraint. The hinge is constrained in width. The thickness is not constrained. I wish to know which would be the lightest material to use and the thickness required to make the hinge.
The thickness of the hinge is constrained for each material due to their ultimate strain - the elongation at which they break - regardless of the strength or stiffness. Since we are optimising, the hinge will break as soon as it passes it's design bend radius. At this radius, the upper and lower fibres of the hinge will be a certain percentage of the length of the neutral fibre - the breaking or ultimate strain.
Ideally, I am looking for the materials selection parameters, such as those used in the Cmabridge Materials selector and any equations that describe the problem.
So, can anyone offer any ideas about how to progress? I can post an example problem to clarify the issue if needed.
Many thanks!
PS this seems like a classroom problem!
Many thanks!
