Hi, I have a question about meshing surfaces. If I wanted to edit the mesh on the far RH surface in attached picture so that it matches BOTH of the meshes on the adjacent surfaces (which both have different element sizes), is there an easy way to do this? The only way I have found to do this kind of thing is by using the 'mesh - mesh control - custom size along curve' command but this can be quite tedious if you have lots of different meshes to match. Is there a command in the meshing toolbox that allows you to do this more easily? Thanks
