MASS PROP
chicopee
6,199
WOULD ANYONE HAVE A LISP PROGRAM ON CONVERTING MASSPROP FROM A VOLUME UNIT TO A WEIGHT UNIT BY INTRODUCING A DENSITY FACTOR RELATING TO MATERIAL OF THE OBJECT DRAWN.
If someone answers this question, please forward it to me. I am also looking for a very similar lisp routine to return region section properties and place the data into a table/block that I've created. enclad@sbcglobal.net
Hey guys checkout thread555-27590! This is right up your creek.Good Luck
if your looking for a lisp that allows you to select a solid or group of solids then report the weight and center of gravity, then this is your lisp for autocad 2000 and up
;This program draws a point at the centroid of a
;region or solid. The point is drawn on the current
;layer at the current settings. It creates a file
;called deleteme.mpr in c:\temp directory that can
;be deleted if wanted, otherwise the program will
;just overwrite it everytime it runs.
(defun c:CG2002 (/ ss mprfile title c-steel s-steel alumn UHMW Neoprene Pine )
(setq c-steel 0.2833
s-steel 0.286
alum 0.098
UHMW 0.0347
Neoprene 0.045
Pine 0.022)
(setvar "filedia" 0)
(setvar "cmdecho" 0)
(print "Select solids or regions")
(setq ss (ssget))
(command "massprop" ss "" "y" "c:/temp/deleteme")
(setvar "filedia" 1)
(setq mprfile (open "c:/temp/deleteme.mpr" "r"))
(read-line mprfile)
(setq title (read-line mprfile))
(close mprfile)
(if (= nil (wcmatch title "*REGION*")) (CG-SOLID) (CG-REGION))
(defun CG-REGION (/ mprfile area-line x-line y-line x-coord
area-size y-coord point-coord old-osnap
weight-cs weight-ss weight-al weights)
(repeat 3 (read-line mprfile))
(setq area-line (read-line mprfile))
(setq x-line (read-line mprfile))
(setq y-line (read-line mprfile))
(close mprfile)
(setq area-size (atof(substr area-line 25))
weight-cs (* area-size c-steel)
weight-ss (* area-size s-steel)
weight-al (* area-size alum)
weight-UHMW (* area-size UHMW)
x-coord (atof(substr x-line 25))
y-coord (atof(substr y-line 25))
point-coord (list x-coord y-coord)
old-osnap (getvar "osmode")
(setvar "osmode" 0)
(command "point" point-coord)
(setvar "osmode" old-osnap)
(setq weights (strcat "Weights at 1 inch thick: " (rtos weight-cs 2 1) "# cs, "
(rtos weight-ss 2 1) "# ss, " (rtos weight-al 2 1) "# al " (rtos weight-UHMW 2 1) "# UHMW "))
(alert weights)
(print weights)
(princ)
(defun CG-SOLID (/ mprfile vol-line x-line y-line z-line x-coord
y-coord z-coord vol-size point-coord old-osnap
(repeat 4 (read-line mprfile))
(setq vol-line (read-line mprfile))
(setq z-line (read-line mprfile))
(close mprfile)
(setq vol-size (atof(substr vol-line 25))
weight-cs (* vol-size c-steel)
weight-ss (* vol-size s-steel)
weight-al (* vol-size alum)
weight-UHMW (* vol-size UHMW)
z-coord (atof(substr z-line 25))
point-coord (list x-coord y-coord z-coord)
(setvar "osmode" 0)
(setq weights (strcat "Weights: " (rtos weight-cs 2 1) "# cs, " (rtos weight-ss 2 1)
(alert weights)
(print weights)
(princ)
