I have a 6000 psig nitrogen cylinder. I'm not sure the setting of the regulator outside of the cylinder. The nitrogen flows to a nitrogen accumulator tank, and fills it so that the pressure in the accumulator is the same as the pressure in the cylinder. On the outside of the accumulator is a fast acting valve. We use this valve to pulse nitrogen into our system. The pipe coming from the fast acting valve is a 3/4' schedule 80 pipe. I need to figure out how to find the flow rate of nitrogen if the fast acting valve goes from closed to 100% open and then closes again in .75 seconds. Any help would be appreciated!!
