The following is in regards to MJSC design code for masonry walls for ASD design (not slender-walls).
Say you have a wall section and you apply your axial and moment forces simultaneously. So you iterate to find the depth of the neutral axis (similar to a concrete beam-column). Now you can find your compression force based on the maximum allowable masonry compressive stress which is typical F'm/3. Then you find your nominal compressive strength based on the compressive pressure and triangular area. You have already satisfied the requirement of not exceeding the maximum allowable compressive force for combined axial and flexure.
Now, when determining the allowable axial capacity. Do you reduce your nominal compressive force or compressive stress that was previously found when considering flexure. Or do you ignore the moment and apply the reduction factor based on the entire wall being in compression. Then compare this to the axial force?
Thanks in advance!
EIT
Thanks in advance!
EIT
