I am in the process of the lateral design of a single story, rectangular, masonry shear wall and wood diaphragm building. The shear load is being transferred to the shear walls from the diaphragm through a continuous wood ledger, and anchors into the face of the masonry wall every so often (16-32”).
I am getting tripped up on the diaphragm shear calculation. In an effort to expedite the design, I was going to try and only check one shear wall along each line.
Once I generate the in plane shear in one line of wall, am I able to use the entire length of wall in my diaphragm shear calculation, or should I only be using the length of my single shear wall.
My direct superior has always used the entire length of wall (longer dimension) to collect the shear, and then dump all of the shear into a single shear wall. He was not able to provide a great reason for it. I can see this making sense because I have (2) continuous #5 in my bond beam that are effectively dragging my load down into the shear wall, so as long as the 2 bars can take the tension/compression that a collector normally sees, then we are all good.
Just wanted to see if anyone had any opinions on this. I will post a sketch tomorrow.
