structSU10
- Mar 3, 2011
- 1,062
I have an existing two wythe brick wall with openings too close together where the repair concept was to infill every other opening to make it a solid wall. The questions was asked - to appease the historical society - that the edges not be toothed in so the 'definition' of the window opening remains. I need the full width of the pier to be structural for the out of plane loading. I am unsure if this vertical head joint is problematic for this or if I can provide wire ties across that head joint to tie things together appropriately such that it can be viewed as a solid wall panel. Does anyone have insights on this repair technique?
