I am studying for my PE exam and I stumbled upon this issue and I cannot wrap my head around it. Can any of you please provide some guidance?
The MSJC-11 Section 1.9.6 defines the Effective Compressive Width Per Bar as the least of:
a) Center to center bar spacing
b) Six times the wall thickness
c) 72 in.
Where does this effective width apply?
I have been looking through my text book from college and there is an example problem on the design of a concrete block wall under eccentric axial load.
The example has four parts:
1.) ASD - Unreinforced
2.) ASD - Reinforced
3.) LRFD - Unreinforced
4.) LRFD - Reinforced
For Part 1, the effective width does not appear to be used, but Anet is calculated per foot of wall.
For Part 2, the effective width is 48" because rebar is spaced every 48". An is not used, but the effective width b is used as 48" in the force equilibrium equation. For example:
P=C-T
2960lbs = 24,000*(4/3)/16*(kd/(7.625/2-kd))*(48)*kd/2-As*24,000*4/3
For Part 3, the effective width does not appear to be used, but Anet is calculated per foot of wall.
For Part 4, The effective width is "defined" as equal to 32" because of the maximum bar spacing, but the book then says, "therefore, b = 12 in./ft of wall." I don't understand why they say the effective width is 32", but then still use b = 12". Anet is calculated per foot of wall. For force equilibrium, they use:
Pn=C-T
659 = 0.8*f'm*0.8*c*(b = 12)-As*fy
Does the effective width as defined in MSJC 1.9.6 only apply to ASD design?
I hope this makes sense. Please feel free to request more clarity. Thank you in advance for any help!
c) 72 in.
P=C-T
Pn=C-T
