A
aus_kel67
Guest
Hi all. I have a singular manuf file with mutipul operations in each. Each operation has multipul sequences in each.
I have created a FRM that for drawing shows one operation for each drawing sheet showing all info for that operation.
In manuf I have created combined views ( layer, orientation ) for each operation.
In layers I have a layer for each CSYS.
For each CSYS layer the current operation CSYS is on & all other CSYS are blanked.
Then I save layer state for each layer.
In manuf I have the combined view tabs turned on at bottom of screen.
When I click on each tab it orientates for that operation & shows only the correct CSYS ( except for workpiece which is not working that way ).
So heres the problem ....
I make a drawing using my FRM select the last process state for that operation, add general view , select combined state for that operation it shows the correct CSYS.
When I add another sheet & do the next operation it shows the correct CSYS again.
Now flip back to first sheet & either the wrong CSYS is there or its gone.
I have been trying so many things & just cant seem to get it.
Can anybody shine some light on my problem please.
