kingnero
- Aug 15, 2009
- 1,780
When welding large hadfield castings, several months later we encounter cracking and chipping (loss of material) in/near the weld zone.
Situation: Hadfield castings, loaded in severe shock loads.
Repair weld of worn zones by a butter layer of 307, followed by welding of high-manganese elektrode (same material as base material) (both SMAW).
grinding before welding, followed by dye testing.
Trying to keep interpass temps below 200 C (400 F).
Any ideas what the aligned black lines are you can see in the grains? is that already carbide precipitation?
Picture is upside down: top part is base material (Hadfield), below you'll see first layer of 307.
PS this has already been briefly discussed here: thread 329658
any other ideas about above picture or ideas/suggestions about welding Hadfield castings?
