Making Matensitic SS Weldable
metman
Materials
Feb 18, 2002
1,187
An article by the subject name was in Fastening and Joining appended to subscription for Machine Design Magazine.
Googled which took me to something called emailinstitute. I tried registering there but ....?????
Anybody know how to access that article?
BTW: SS is spelled-out in the article title.
Design for RELIABILITY, manufacturability, and maintainability
I did receive an email notification from emailinstitute. It is about masrketing via email and no relsults for my search.
Saved Search & Alert Name:weld martensiticKeyword: martensiticstainless steel
Brand: N/A
Parent Company:N/A
Email type: N/A
Industry:Manufacturing
Displaying [highlight]0 of 0 [/highlight]emails matching your search criteria:
Your search did notreturn any results.
1. Use elevated preheat
2. Use low carbon content martensitic stainless steel base material
3. Use 410 NiMo filler metal
With low carbon like 410S , the martesite that forms is not "very" hard, and(as noted) with preheat ,it may not crack.
I would not trust it in critical applications/
We laser weld 440C every day of the week. No martensite.
dgallup said:
...No martensite.
I understand the use of preheat and low carbon 410 noted by metengr and blacksmith37.
Are you lazer welding with or without filler and if without, how do you avoid martensite with the high carbon and high alloy in 440C which cause sluggish transformation?
I have a question:
Is it possible during heat treatment in a vacuum furnace, oil or gas quench for stainless steel parts to fusion weld to one another? Could this happen at around 1070 °C?
Specifically: 440C austenitized to 1070 °C. Parts seem to fusion weld to each other, worse with oil but also with gas quench. My ASM heat treatment states that the austenitizing temp for 440C is 1010-1065 °C, and we onsite always add a rule of thumb an extra 5 °C to our furnace program soak temps. The heat treatment basket in which they sit in is 316L stainless, if that makes any difference. What I believe is happening is that we replaced our insulated box within the furnace about a year ago, and that is being more efficient with heat retention, therefore the temperature uniformity is better within the box, and 1070 °C is now slightly too high an austenitizing temp.
Thanks for your help.
Ian
Metman
No filler. The short answer is I don't know but we have had the welds checked by outside labs. I suspect the extremely small size of the welds & HAZ plays a role.
All martensitics SSs are not equal, so there is no single answer. A lot of older (pre-www) literature gives advice for welding as if all grades are treated the same as 410.
To add to comments by metengr, when/if possible, use auitenitic stainless filler metal like E/ER309 or Nickel base alloy filler metals which have an affinity for hydrogen.
Make sure the Martensitic Stainless Steel is in the annealled condition before attempting to weld it, even with high preheat.
Best regards - Al
