Making angled CS flat for detailing.
  • Thread starter Thread starter MOTO
  • Start date Start date
M
MOTO
Guest
Is it possible to make an angled cross section flat so I can dimension the part in one cross section rather than two. Picture a revolved part with a pie piece removed, I would like to flatten both visible parts of the remaining pie.
Thanks in advance.
Moto
Yes.
Oh, I bet you want to know HOW to do it. That's not what you asked. It is called an Aligned cross-section:
Restrictions on Aligned Cross-Sections
An aligned cross section displays an area cross-sectional view that is unfolded around an axis. The system revolves all cutting planes of an offset cross-section about the selected axis until they are oriented parallel to the screen (sheet).
Aligned cross sections create area-type cross sections. A full aligned cross-section shows an aligned total cross section of a general, projection, or auxiliary view. You can make a detailed view from an aligned cross-sectional view.
The following restrictions apply to both aligned cross-sectional views and total aligned cross-sectional views:
You can align offset cross sections only.
The axis around which the cutting planes revolve must be parallel to the screen.
The axis must lie on all cutting planes.
The axis must be coaxial with all cylinders in the section.
Dimensions can be created within one segment of a cross section.
If the view is to be general, orient the model so that the axis around which you are going to unfold is parallel to the screen.
Pro/ENGINEER creates aligned and unfolded cross-sectional views as area cross sections.
nice answer DR_G lol
here it is
1.front view create an offset view in view manager
2. top view
3. cross section
4. local section
5. this is prob what u want its called full aligned
Edited by: megaladon
Thanks guys...
Worked like a champ... I knew if Inventor could do it, Wildfire could do it.
Moto
i think thats all inventor can do
o it does seem to import excel files a little better than pro does too but
then again inventor is for kids to design legos & pick up stix
Thats funny...
