Make block
RAMviking
NO
Hi,how do I make a Block?
I´m trying to make
blocks so revision notes ("Issued for construction" etc.)can easily be inserted.
And where shall I save the blocks?
ST4 on a Macbook pro with 8Gb RAM
Yes, it works fine :-)
What about using a note instead of a block? I assume you are working in the drafting environment.
You can save note in the annotation command.
Patrick
I would also like to do this.
Do I use "Callout" or "Text" from the Annotaion section on the ribband.
Thanks...
I have used a table to generate drawing revisions in draft.
It can easilly be updated to add rows and columns.
-av8errr
Solid Edge ST3 MP9
xw4600
3GB RAM
Core2Quad CPU 3.00GHz
NVIDIA Quadro FX4800
I´ve tried with callout, but I am not satisfied.
Before I put in the text i do not want to have unused lines or rows.
When I put in text REV A, REV B and so on I will have lines and rows around the text.
Solid Edge ST4 Premium
MACBook pro 8GB RAM
In that case either a table, or you may be better doing it in the background sheet as part of the drawing template - that's how we do rev block, in the background sheet, adding rows as needed, using just text blocks not callout. The rest of the border is put on a layer that's locked, you could do similar with blocks.
Not saying that's optimum though.
Thanks Kenat.
I have entered all my standard notes and given them names that I can recall them by.
It works great....cheers
Tim
