make a copy into a separate part 1
AlbertH22
What is an easy way to change a part (that was copied from a part in an assy) into a new separate part?
To expand on Chris's statement;
If the assy is open, and witht he copied part open in it's own window,use the Save as function, but be sure to select the Copy option.
After saving, return to the assy and use the Replace Components with the All Instances option NOT selected, to switch the copied part to the newly saved part.
Does it have a drawing associated with it? The 'pack and go' feature in SW Tools has never steered me wrong.
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz 11.9 GB of RAM
