Any body know of tricks to create rectangular wear?
mineral crusher dryer hammer mill.
There is a row of stationary "crusher blocks" that can be adjusted inward to reduce the working clearance with the mill running.
The hammers' working edge wears to a rounded shape and performance suffers even with tightened gaps. The wear is described as a combination of erosion and abrasion. Different hammer materials are used to resist wear, but of course some materials we crush throw corrosion into the mix, making stainless type materials necessary at the expense of wear resistance.
I seem to recall some cutting tools can "wear" to create a fresh cutting edge, but suspect that may be more of a brittle fracturing process. I'm pondering a system with multiple edges behind each other, kind of like a multi-blade razor.
