My client is planning to utilize the existing distribution system to convey the newly treated water with pH level of 6 to 7. Since the water is treted with RO and pH adjustment, its mineral content, including calcium, is very low. The distribution system is made up of cement-lined iron pipes, and it's concerned that the aggresive water will cause the leaching of lime from the cement lining and expedite it's failure. In addition, due to the high organic content of the current water flowing to the distribution line,a significant biofilm covers the inside walls of the distribution system pipes, and that the introduction of the newly treated water which is low-organic type of water will result in the sloughing of large masses of this biofilm that delivers to the customer.
The problem is once the water reached the consumer the pH spikes to level of 10 & above. Will there be any solution to solve this problem before it reach the consumer? What chemicals should be added and at what doses if the new treated water is 116,000 m3/day?
