Dario2002
Petroleum
- Aug 25, 2006
- 33
I see that many posts regarding demagnetization topic is present in this forum. Let's try to be more practical.
Let's say we have 20" pipe, and we measure 35 gauss on pipe end. Heat treatment is probably not suitable for demagnetization. Next option is demagnetization using welding cables. How many coils we should make, and what current (AC) we should give through those cables. Is there any calculation model for this?
1) Can we help our selfs if start with some stronger current, then reducing gradually? How fast?
2) Can we help if put current through cables and move them out from pipe?
3) Reversing polarity few times?
4) Can it help to connect those pipes somehow before welding (ground bridge)?
And one theoretical question. We have info from pipe welders that magnetization was not uniform on pipe end (circumferential). Is this possible to have areas at circumferential edge with different levels of magnetization? What difference of magnetization in pipe steel can be expected (gradient at one meter or 1 cm)?
