I have a question regarding magnetics which I can't find a definite answer for, hoped someone could help. The question is "If a static hoop of iron, eg. a horseshoe, is set near a rotating cylindrical permanent magnet which has north pole at one end and south at the other so that one end of the hoop approaches the north pole and one end approaches the south pole, is a torque imparted to the hoop? How much?"
N -]=[- S
U
The core issue is, does this setup cause the breaking of magnetic lines of force in a manner similar to eg. a claw-pole synchronous generator where the hoop is rotated 90 degrees and the magnetic shaft has alternate projections inward from each pole? BTW, I have little access to handbooks or texts, appreciate web ref's etc.
Thanks for your help
Pechez les vaches.
N -]=[- S
U
Pechez les vaches.
