magnetic attraction 1
Almiester
How would you model magnetic attraction? As a force? A pressure? or a spring? If a spring,how do you determine the spring constant?
1- as a spring with negative constant
2- determine field magnetic force at a reference distance, then divide the force by the distance. Example: in the case of a generator, calculate field asymmetry at 10% of the air-gap, calculate magnetic force, then K=-F/(0.1*a).
