Terry,
There are real benefits to using magnesium alloys for transmission cases. I was imprecise in my first post - Al alloys have higher E/&[ignore]rho[/ignore];, but transmission cases are bending critical components, and therefore the property index is either E0.5/&[ignore]rho[/ignore]; or E0.33/&[ignore]rho[/ignore];. Mg alloys are superior under these conditions.
Automotive transmission cases are made using high pressure die casting, not sand casting. Therefore, suitable alloys are AZ91D and A380. Using Matweb for properties, one can calculate the following:
[tt]
Property AZ91D A380
E 44.8 71
&[ignore]rho[/ignore]; 1.81 2.76
E/&[ignore]rho[/ignore]; 24.75 25.72
E0.5/&[ignore]rho[/ignore]; 3.70 3.05
E0.33/&[ignore]rho[/ignore]; 1.96 1.50
[/tt]
Mg alloys do have larger thermal expansion, and the cost can be higher (~10%-50% depending on design, volume, etc.). Dolomite is one of the major ores from which to obtain magnesium metal.
Cory
