Macro
CycloneWade
Automotive
I'm looking for some help in creating a macro that will start a sketch on a preselected face and offset a preselected loop and extrude the new sketch x number of units. I've created a macro but macro becomes attached to that specific face on that specific part. A little guidance should be adequate. Thanks.
Make sure you clear the SelectionManager selections before you close the macro.
Okay I finally crippled together some code, which for now appears to work.
Dim swApp As Object
Dim Part As Object
Dim SelMgr As Object
Dim boolstatus As Boolean
Dim Feature As Object
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Set SelMgr = Part.SelectionManager
Part.SketchManager.InsertSketch True
boolstatus = Part.SketchOffsetEntities2(0.00127, False, True)
Part.ClearSelection2 True
Part.FeatureManager.FeatureExtrusion True, False, True, 0, 0, 0.00127, 0.00254, False, False, False, False, 0.01745329251994, 0.01745329251994, False, False, False, False, 1, 1, 1
Part.SelectionManager.EnableContourSelection = 0
End Sub
