I realise this is a little cheeky, but it's less than a month until I start my new role and I need to get as much done in my present role as possible. Some might ask 'why bother, you're going to a new job?', as it's within the same company I don't want to let them down and do nothing for the final month...
Anyway, enough of that cr4p. My problem is with Family of Parts. At this company we have a lot of products that have a base set of dimensions, then the customer has a specific shaft size and we machine the product out to suit. This creates a lot of detail drawings, so we use FoPs. But here's the problem, when you populate out a FoPs the part members have no mass until you go to Physical Properties and press the Update button. As I'm the one creating most of these to start with (from 2D tabulated drawings) is it easy for someone (and here's the cheeky bit) to write a macro that does the following?
- I select and open up the file,
- I press a macro button,
- The part gains a mass (macro updates physical properties)
- The part gets saved and closed
- I move onto the next file...
Feel free to flame me
Cheers,
M
Cheers,
M
