Macro with an input dialog box with dropdown 1
TiagoFigueiredo
Industrial
PT
I everyone,
I am trying to make a macro which contains a dialog box, with a dropdown menu, with some predefined values. Any one have tried?
For example:
I would like to run the macro and the dialog box show the sizes of available threads diameters (M4, M5, M6, M8, M10...) Instead of write this values. It's possible to make this?
you can do it using VBA and a Form
Eric N.
google does
Eric N.
Yes you are right, i forgot to say that i'm trying to make that in a macro in Catia. My macro is written in CATScript, and i'm realizing that is not possible with CATScript. Do you suggest to change it to vba?
Maybe you can modify this example...
file attached for testing..
Code:
Sub CATMain()
CreateProgressBar
Launch
End Sub
Sub CreateProgressBar()
    Dim ws, fso, Temp, PathOutPutHTML, fhta
    Set ws = CreateObject("wscript.Shell")
    Set fso = CreateObject("Scripting.FileSystemObject")
    Temp = ws.ExpandEnvironmentStrings("%Temp%")
    PathOutPutHTML = Temp & "\ModifyInstances.hta"
    Set fhta = fso.OpenTextFile(PathOutPutHTML, 2, True)
fhta.WriteLine "<html>"
fhta.WriteLine "<head>"
fhta.WriteLine "<title>Text</title>"
fhta.WriteLine "<HTA:APPLICATION "
fhta.WriteLine "ID=""objHTA"" "
fhta.WriteLine "APPLICATIONNAME=""Catia_Dropdown"" "
fhta.WriteLine "SCROLL=""NO"" "
fhta.WriteLine "SINGLEINSTANCE=""yes"" "
fhta.WriteLine "Caption = ""no"""
fhta.WriteLine ">"
fhta.WriteLine "</head>"
fhta.WriteLine "<script language=""VBScript"">"
fhta.WriteLine " Sub Window_Onload"
fhta.WriteLine "Dim intWidth, intHeight"
fhta.WriteLine "intWidth = 300"
fhta.WriteLine "intHeight = 100"
fhta.WriteLine "Me.ResizeTo intWidth, intHeight"
fhta.WriteLine "LoadDropDown"
fhta.WriteLine "End Sub"
fhta.WriteLine "Sub LoadDropDown"
fhta.WriteLine "For I=2 TO 10"
fhta.WriteLine "Set objOption = Document.createElement(""OPTION"")"
fhta.WriteLine "objOption.Text = I"
fhta.WriteLine "objOption.Value = I"
fhta.WriteLine "objDrop.Add(objOption)"
fhta.WriteLine "Next"
fhta.WriteLine "Sub SendToCatia"
fhta.WriteLine "Dim CATIA"
fhta.WriteLine "Set CATIA = GetObject(, ""CATIA.Application"")"
fhta.WriteLine "Dim oPartDocument "
fhta.WriteLine "Dim oPart"
fhta.WriteLine "Dim oCircularPattern "
fhta.WriteLine "Set oPartDocument = CATIA.ActiveDocument"
fhta.WriteLine "Set oPart = oPartDocument.Part"
fhta.WriteLine "Set oCircularPattern = oPart.FindObjectByName(""CircPattern.1"")"
fhta.WriteLine "oCircularPattern.AngularRepartition.InstancesCount.Value = objDrop.value"
fhta.WriteLine "oCircularPattern.CircularPatternParameters = catCompleteCrown"
fhta.WriteLine "oPart.Update"
fhta.WriteLine "window.close"
fhta.WriteLine "</script>"
fhta.WriteLine "<body>"
fhta.WriteLine "<select name=""objDrop"">"
fhta.WriteLine "</select>"
fhta.WriteLine "<input type=""button"" value=""Send To Catia"" name=""cATIABtn""  onClick=""SendToCatia"">"
fhta.WriteLine "<input id=""BtnExit""   type=""button"" value=""Cancel""   onclick=""window.close"">"
fhta.WriteLine "</body>"
fhta.WriteLine "</html>"
fhta.Close
End Sub
Sub Launch()
Set objShell = CreateObject("Wscript.Shell")
Temp = objShell.ExpandEnvironmentStrings("%Temp%")
objShell.Run (PathOutPutHTML), 1, True
End Sub
______
Alex ,
 http://files.engineering.com/getfile.aspx?folder=415424ea-e2c3-40d9-a122-6c09444bb426&file=CircPattern_HTA.CATPart
Many thanks about this, it looks really what i need. Thanks by your help.
