Macro to remove geoset
Caddish
Automotive
Nov 13, 2015
I'm trying to do a macro that will remove the selected geo set while keeping the content.
There is already a function in Catia that does this called "Remove Geographical Set" but the macro recorder does not catch it and I can't find it in HybridBody objects
Alternatively I was thinking of manually moving everything in the GS before it and then deleting it but it's a bit past my skill.
Anyone able to help me ? I'm experienced in VBA/VB.Net but totally new to Catia API so any exemple is welcome
Thanks !
Remove Geoset will only remove the geoset...not the features inside...I think you can access it from the StartCommmand. Look at View > Command List to see the strings for StartCommand. If you want to delete the stuff inside you can delete the geoset and it will automatically delete everything inside...beware, if any other features are children to the ones you deleted, they will not update.
In its simplest form:
Code:
'load part and add geoset to selection then run macro
sub RemoveGeoset()
If Catia.activedocument.Selection.count > 1 then
[indent]CATIA.StartCommand ("Remove Geographical Set")[/indent]
End if
end sub
To delete the geoset:
Code:
sub DeleteGeoset()
[indent]CATIA.activedocumnet.selection.delete ("Remove Geographical Set")[/indent]
End if
end sub
It would be worth you looking at the V5Automation.chm file to get started with CATIA macros.
What kind of Geo Set is it? What do you have inside? Where do you want to move those elements? Are you in v5 or v6? Are you in a CATPart window or CATProduct window? Do you have vba available or not?
I'm asking all these because I recently saw something similar in v6...
Fernando
@lardman
Thanks ! I did not know about CATIA.StartCommand. I have browsed V5Automation.chm but it is a mess (least compared to Solidworks Api Help)
@ferdo
It is a GSD geoset either in a catpart windows or in a catpart in a catproduct with Catia V5 and VBA
The logical process should be (and is not quite all):
- select the GS
- copy everything inside
- get the name of GS
- activate the CATPart where is this GS
- create a new temporary GS
- select the new GS and paste everything from memory inside
- search and delete old GS, you already know the name
Simple, isn't it? Parts of all this process can be found in V5Automation.chm or CATIA_Portable_Script_Center.
Fernando
- Romania
- EU
