I used a macro in CATIA to instantiate a power copy which uses a design table. I was wondering how i could isolate the design table's link.
Once the power copy is made, i do not want the design table to be linked with my excel sheet on my server.
Here is the macro i used to instantiate the power copy (found in CATIA's documentation):
' Instantiation of a Power Copy Reference called "TwoSurfacicHole"
' TwoSurfacicHole is stored in the CATPart PowerCopyReference.CATPart"
' It has 3 inputs: FirstHole, Support,and SecondHole
' and 2 published parameters: Radius1 and Radius2
CATIA.SystemService.Print "Retrieve the current part"
Dim PartDocumentDest As PartDocument
Set PartDocumentDest = CATIA.ActiveDocument
Dim PartDest As Part
Set PartDest = PartDocumentDest.Part
CATIA.SystemService.Print "Retrieve the factory of the current part"
Dim factory As InstanceFactory (A)
Set factory = PartDest.GetCustomerFactory("InstanceFactory")
CATIA.SystemService.Print "BeginInstanceFactory" (1)
factory.BeginInstanceFactory "TwoSurfacicHole", "e:\tmp\PowerCopyReference.CATPart"
CATIA.SystemService.Print "Begin Instantiation"
factory.BeginInstantiate (2)
CATIA.SystemService.Print "Set Inputs"
Dim FirstHole As Object
Set FirstHole = PartDest.FindObjectByName("Point.1")
Dim Support As Object
Set Support = PartDest.FindObjectByName("Extrude.1")
Dim SecondHole As Object
Set SecondHole = PartDest.FindObjectByName("Point.2")
factory.PutInputData "FirstHole", FirstHole (3)
factory.PutInputData "Support", Support
factory.PutInputData "SecondHole", SecondHole
CATIA.SystemService.Print "Modify Parameters"
Dim param1 As Parameter
Set param1 = factory.GetParameter("Radius1") (4)
param1.ValuateFromString("25mm")
Dim param2 As Parameter
Set param2 = factory.GetParameter("Radius2")
param2.ValuateFromString("15mm")
CATIA.SystemService.Print "Instantiate" (5)
Dim Instance As ShapeInstance
Set Instance = factory.Instantiate
CATIA.SystemService.Print "End of Instantiation"
factory.EndInstantiate (6)
CATIA.SystemService.Print "Release the reference document"
factory.EndInstanceFactory (7)
CATIA.SystemService.Print "Update"
PartDest.Update
Thank you!!
PartDest.Update
Thank you!!
