Macro to change child configurations of assemblies to the default config
btcoutermash
Industrial
All,
I have a situation where I have a top level assembly with many sub assemblies. I would like to run a macro in the top level assembly that would take all the sub assemblies and switch them to use the "default" configuration. Would anyone have know how I could do this??
I don't. Maybe some programming involved.
You can select with Ctrl-select all of them and change all at once.
Chris, CSWA
SolidWorks 14
SolidWorks Legion
Try following ctophers advice and record a macro when you do it. That will give you a majority of the code. Then its a matter of you getting the code to do it for any file you have actively open.
Scott Baugh, CSWP [pc2]
"If it's not broke, Don't fix it!"
faq731-376
