Option Explicit
Dim swApp As Object
Dim swPart As Object
Dim swDwg As Object
Dim strNewLine3 As String
Const swDocDRAWING = 3
Const swDocPART = 1
Const swDocASSEMBLY = 2
Const swOpenDocOptions_Silent = &H1
Dim retval As Boolean, retval1 As Long, lngOha As Long
Dim sMask As String
Sub Main()
Dim sPath As String
Dim sFileSW As String
Dim sFileDWG As String
Dim sFileDXF As String
Dim sFilePRN As String
Dim sFileTitle As String
Dim iParts As Integer, iAssy As Integer, iDrw As Integer
Dim sMsg As String
sPath = BrowseForFolder(0, "Please select a Server folder.")
If sPath = "" Then
Exit Sub
Else
sPath = sPath & "\"
End If
sMsg = "Enter drawings mask (if applicable). Use '*' for all."
sMask = InputBox(sMsg, "Drawings Mask", "*")
If sMask = "" Then sMask = "*"
Set swApp = CreateObject("SldWorks.Application")
iParts = 0
iAssy = 0
iDrw = 0
'process parts
sFileSW = Dir(sPath & sMask & "*.sldprt")
Do While sFileSW <> ""
'Open file
Set swPart = swApp.OpenDoc2(sPath & sFileSW, swDocPART, False, False, True, lngOha)
If swPart Is Nothing Then
Call MsgBox("Unable to open document!", vbExclamation, "Line3") ' Display error message
End ' If no model currently loaded, then exit
End If
'counter
iParts = iParts + 1
'do part processing
'save file
retval1 = swPart.Save2(True)
'Close File
sFileTitle = swPart.GetTitle
swApp.CloseDoc sFileTitle
'Next File
sFileSW = Dir
Loop
'process assemblies
sFileSW = Dir(sPath & "*.sldasm")
'Open file
Set swPart = swApp.OpenDoc2(sPath & sFileSW, swDocASSEMBLY, False, False, True, lngOha)
End If
'counter
iAssy = iAssy + 1
'do assembly processing
'save file
'Close File
'Next File
sFileSW = Dir
Loop
'process drawings
sFileSW = Dir(sPath & "*.slddrw")
'Open file
Set swPart = swApp.OpenDoc2(sPath & sFileSW, swDocDRAWING, False, False, True, lngOha)
End If
'counter
iDrw = iDrw + 1
'do drawing processing
'save file
'Close File
'Next File
sFileSW = Dir
Loop
swApp.SendMsgToUser Str(iParts) & " parts, " & Str(iAssy) & "assemblies & " & Str(iDrw) & " drawings changed in folder" & vbCrLf & _
sPath & " !"
End Sub
