I want to make a macro that will create a section box in DMU .
Until now I have this code but is not exactly what I need:
The problem is that the macro create a section box after the Z axis ( as you can see in the picture attached), but I need it after the X axis.
This is my first macro that I am trying to write ... so I don't know exactly where can I find the neccesary code.
(I also posted my question at: )
Thank you!
Code:
Sub CATMain()
' Retrieve the Sections collection
Dim cSections As Sections
Set cSections = CATIA.ActiveDocument.Product.GetTechnologicalObject("Sections" [Wink]
' Create the master section
Dim oMasterSection As Section
Set oMasterSection = cSections.Add
' Retrieve data on master section
Dim Position(11)
oMasterSection.GetPosition Position
Dim SectionType As CatSectionType
SectionType = oMasterSection.Type
oMasterSection.Type = catSectionTypeBox
Dim SectionMode As Integer
SectionMode = oMasterSection.CutMode
oMasterSection.CutMode = 1
Dim SectionWidth As double
SectionWidth = oMasterSection.Width
oMasterSection.Width = 3500.
Dim SectionHeight As double
SectionHeight = oMasterSection.Height
oMasterSection.Height = 7000.
Dim SectionThickness As double
SectionThickness = oMasterSection.Thickness
oMasterSection.Thickness = 600.
Dim MatrixPos (11) As Double
MatrixPos( 0) = 1.0
MatrixPos( 1) = 0.0
MatrixPos( 2) = 0.0
MatrixPos( 3) = 0.0
MatrixPos( 4) = 1.0
MatrixPos( 5) = 0.0
MatrixPos( 6) = 0.0
MatrixPos( 7) = 0.0
MatrixPos( 8) = 1.0
'is the X component of the origin
MatrixPos( 9) = 11538.0
'is the Y component of the origin
MatrixPos(10) = 0.0
'is the Z component of the origin
MatrixPos(11) = 1750.0
oMasterSection.SetPosition MatrixPos
End Sub
Thank you!
