Macro locations
sdb999
Has anyone figured out how to get SW to obey the "Tools-Options-File Locations-Macros" setting? It seems to only look at the install directory no matter what path is defined in this field.
I have not played with it but in the past, SolidWorks looked only in the install directory when you assign a macro to a key on the keyboard.
It works fine here. We have 4 seats, and I have them all set to a network location for macros.
What OS are you using?
Also, macros need to be in the install directory if you are trying to place them on the menu using "Tools --> Customize"
[bat]All this machinery making modern music can still be open-hearted.[bat]
XP professional 5.1, and yes I am trying to assign them to function keys. Are you saying you maintain five copies of your Macros, one on the network drive and another on each users' local drive?
No, I don't do that. I just have the users access macros through "Tools --> Macro --> Run"
I recently acquired VB 6.0 and will be converting macros to exe's and adding them to the main menu.
One possibility: create a macro to store locally that kicks off a macro stored on the network. That way, you only have to maintain one "working" macro.
retval = SldWorks.RunMacro ( filePathName, moduleName, procedureName )
Ok, so if we want to click thru Tools-Macro-Run we can have one location for all our macros. If we want a single key stroke they have to be duplicated on each user's local drive. As a hybrid we can start each macro via a local that mearly kicks off the network version. It's all starting to make sense (in a SolidWorks kind of way). Thanks All.
I put the macros onto everyone’s C:\Program Files\SolidWorks\Macros directory. That macro will start our visual basic Exe program. There is only one copy on the network. Here is an example of what I use.
Option Explicit
Dim swApp As Object
Dim Part As Object
Dim MyAppID, ReturnValue
Sub main()
Set swApp = CreateObject("SldWorks.Application")
Set Part = swApp.ActiveDoc
MyAppID = Shell("\\Athena\Eng\Applications\SolidWorks\Executables\Titleblock.exe", 1)
End Sub
Bradley
