Macro for normal to surface lines 3
macocata
Aerospace
RO
I want to create a macro with the next structure:
Input: a geometrical set which contains a surface and a lot of points (200 up to 1000 points)
Output: a new geometrical set that contain normal to input surface through each input point
I have already done a the next script.
I have to specify that in my geometrical set the surface is on the firs position of selection and after that are those points.
My macro fails at the red line, if I replace parameters1.Item(1) with parameters1.Item("surface_name") it works, but i want to make the macro for any different surfaces names.
Sub CATMain()
Set partDocument1 = CATIA.ActiveDocument
Set selection1 = partDocument1.Selection
selection1.Search "(CATGmoSearch.Surface + CATGmoSearch.Point),sel"
Set part1 = partDocument1.Part
Set hybridShapeFactory1 = part1.HybridShapeFactory
Set parameters1 = part1.Parameters
Set hybridShapeSurfaceExplicit1 = parameters1.Item(1)
Set reference1 = part1.CreateReferenceFromObject(hybridShapeSurfaceExplicit1)
Set hybridBodies1 = part1.HybridBodies
Set hybridBody1 = hybridBodies1.Item("Geometrical Set.1")
Set hybridShapes1 = hybridBody1.HybridShapes
Dim i As Integer
For i = 2 To selection1.Count
Set hybridShapePointOnSurface1 = hybridShapes1.Item(i)
Set reference2 = part1.CreateReferenceFromObject(hybridShapePointOnSurface1)
Set hybridShapeLineNormal1 = hybridShapeFactory1.AddNewLineNormal(reference1, reference2, -15#, 15#, False)
hybridBody1.AppendHybridShape hybridShapeLineNormal1
part1.InWorkObject = hybridShapeLineNormal1
part1.Update
Next i
End Sub
So any idea?
Thank Ferdo for your help, but I don't want to rename the surface for the simple fact that I can have 2 or 3 different geometrical sets where to create those lines and every time I will have to change names in script or in Catia. Please help me to debug that red line so that the macro can recognize and create lines on the first surface from the selected geometrical set.
My suggestion is to get the name of the surface in the GS (if you don't want t change the name), something like bellow
surfaceforlines = selection1.Item(1).Value.Name
MsgBox surfaceforlines
then change the red line with
Set hybridShapeSurfaceExplicit1 = parameters1.Item(surfaceforlines)
Fernando
Thank you, it works now properly.
Hi, in my case it doesn´t work, fail at line "Dim i As Integer"
I have hundred of copied and linked points in a geoset, I have introduced the surface into the geoset in the first position and introduced the name of the surface inside the text but it doesn´t work. I tried to use Ferdo´s modification on the script but it also fails
I am using V5R20
Can you help me?I am not so familiar with those scripts
I'm very new to scripting in CATIA but I was hoping to gain some help to get the above working. I've had to make some changes to get it progress a little further without erroring ...
1. Add a ' to Next line at the end of the script.
2. Changed Set hybridShapePointOnSurface1 = hybridShapes1.Item(i) to Set hybridShapePointOnSurface1 = parameters1.Item(i) (I couldn't get Ferdo's suggestion to work).
When I run the script the correct surface and points are highlighted. But, how would I modify the script to use a multisection generated surface and points drawn along a curve? After much head scratching I've realised that if I convert these to explicit entities the script runs fine.
Code:
Sub CATMain()
Set hybridBody1 = hybridBodies1.Item("Vectors")
Dim i As Integer
Set hybridShapeLineNormal1 = hybridShapeFactory1.AddNewLineNormal(reference1, reference2, -15, 15, False)
part1.Update
Next 'i
End Sub
Thanks for any help.
Made some typo's for my changes at item 2 but can't edit. I'll leave it at that for now as it's probably not important right now and I can't edit. :)
