macro failure
connery
JP
Hi everybody,
I have tried to make a macro right from starting a component
i.e.file,new,part,and so on but it shows error at the time
of execution.Even when I started making in part template
it was showing error for palette features.
why it is so?what can be done in both the cases?
Thanks!
Connery
Macros only recognize certain commands in SolidWorks. Most system-level input is ignored. (For example, I tried to write a macro to enter a custom property, but it didn't work; I had to use API instead.) Try going through the macro after you save it and make sure it is executing the commands you think it should be.
What is the error message?
When you run a macro it will tell you at what line it encounterd an error, and what the error was. Usually it is an undefined variable or unsuported function.
If you can provide more info, I may be able to help you.
jevakil@mapdi.com
One nuclear bomb can ruin your whole day.
