We recently purchased a high speed router for machining plastic (acrylic, nylon, fiberglass). The parts are covered with paper for protection from scratches and has to be present when machining. The issue is that while machining with a conventional upcut endmill, the paper is not cut clean and either wraps around the cutter or then lifts off the part increasing the risk of pits, scratches etc. We did try using a downcut router bit, which cut the paper but chips did not evacuate cleanly and were re-cut resulting in all sorts of problems. I would really appreciate it if anyone has suggestions on how the paper can be cut clean and at the same time chips pose no problems. Please let me know if you need any further information too.
