Hello everyone,
My company has no machining centers, only a single CMM. Part of our business is refurbishing used machines. This involves CMM measuring the critical used pieces, sending out to perform any machining repairs (usually sleeving and remachining damaged bore features), and bringing the pieces back in for a CMM inspection to verify the repair. All of this is well and good, however it has inefficiencies and can be difficult to balance against support for building new standard machines.
I know that many modern machining centers have built-in CMM ability. I don't need a 3 micron CMM for this kind of work; even a 10 micron CMM would probably work. So it would be interesting for us if there was a large table machine that would permit us to do both inspection and machining repairs on the same platform. Our largest workpiece might be 100" deep x 80" x 80", but an average workpiece fits within a 30x30x30 box. The machining would not be heavy-duty stuff, it would be precision boring within cast iron and low carbon steel, and we can afford to go slow if that helps. So this machine would be used for CMM inspection only, or repair followed by CMM confirmation of the repair.
I know CMM brands and product lines but not machining centers. Is there machinery that supports the kind of dual-purpose work I'm describing? Does the CMM portion of the machining center work like a regular CMM? What brands or machines might make sense for this type of activity?
Thanks,
David
Thanks,
David
