alr
- Nov 12, 1999
- 20
I have recently been asked to design and make a machine for the production of “Bath Bombs”. These are perfumed foaming blocks that are used in spas and baths.
The ingredients (consisting mainly of Epsom salts) are mixed dry and a very small amount of water is added. They can be pressed into the mould by hand (i.e. exerting approximately 10 psi). The machine is to press them directly into the mould, where they can be de-moulded almost immediately and the hopper needs to hold sufficient for 100 units (about 500 cubic inches).
Because of the dry nature of the material, it will not flow and compressing it, hardens it. It is similar in nature (but much finer) to the dry mix used to make concrete slabs. An Auger feed could be used, but my client would prefer a cheaper and easer to clean, design.
I am open to all suggestions.
Tony
Tony
