Machine Drivetrain Efficiencies 2
jerryv
22
What is best way to determine the sum of machine drivetrain efficiencies?
Example:
20 hp motor driving a gearbox (98% efficient), which drives a timing belt (89% efficient) which drives a roller chain(89% efficient). What is total efficiency of the drive system?
See attached file.
Somewhere I have some formulae (formulas?) on calculationg efficiencies -- if I have an opportunity and nobody else answers, I'll look them up.
However, until then, at least a rough estimation could be obtained through the "square root - sum of the squares" method: [√]([η]g2 + [η]t2 + [η]c2)
where the subscripts refer to the gearbox, the timing belt, and the rolling chain, respectively.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Isn't it just 0.98*0.89*0.89 ???
And I can't see how "square root - sum of the squares" would work with the figures quoted, as you appear to end up with a number greater than 1 ???
Multiplication as Peter says is the key.
98% of 100% is 98%
89% of 98% is 87.2%
89% of 87.2% is 77.6%
etc, etc.
You don't magically make up for lower efficiency with a higher efficiency, it still lowers the overall, just not as much.
James Spisich
Design Engineer, CSWP
PeterCharles & JSpisich
You're right -- that's what I get for giving an off-the-cuff answer. The SRSS doesn't work for percentages.
Patricia Lougheed
