I am in the process of designing a machine. I wish to drill and tap the frame to receive screws. I plan on using SAE grade 5 fasteners and need to select a suitable steel for the base material. In reviewing the ASTM specs I spotted A284 as a possible good material (steel, weldable, for machine design) spec. Having a significantly lower yield strength than the grade 5 fasteners, it adheres to the rule of thumb for nuts vs bolts (soft and ductile vs strong and tough). Without having to go through strength of male and female thread calcs is it reasonable to use this material?
cntrlnr
cntrlnr
