I am designing a heat staking fixture (inserts brass
inserts into thermoplastic parts with the aid of heat) for
the injection molding industry. The staking procedure
requires temperatures of around 300 degrees F and the
machine can handle a max of around 1000 degrees F as long
as insulation is present between the heated probe tips and
upper carriage. This insulation is generally 1" thick,
but the identity of the material is kept proprietary by
many manufacturers. The insulation must be MACHINABLE and
able to withstand approx. 100psi. Does Macor sound like a
probable alternative? Does anyone know of a cheap material
that should be able to perform well in these conditions.
I've attached a photo of a similar fixture for reference.
The insulation is the layer sandwiched between the two
aluminum plates.
Thanks!
aluminum plates.
Thanks!
