Hi, I am new here.
I am a beginner musical instrument designer with an interest in innovative hardware for the guitar. I look forward to using this forum to learn about many topics.
Today I am here for very simple stuff really. I hope this is in the right place, I couldn't seem to find a subtopic for such a simple question!
I am drafting a part to have prototyped and am unsure of something. One person has warned me away from using something as small as M2 here, but I am limited on real estate and will have to redesign a significant amount of the product to go bigger, and am quite trapped in the design.
This is the part:
The small grub screws either side of the string that are used to raise the height of the block the string sits on.
M3, occasionally M2.5 is the industry standard.
Is M2 durable enough to be serviceable? What should I use for the grub screw and the block it goes into? Stainless steel?
Both threads and heads need to be durable. They don't have to last for ever, but they are used to adjust the height of a string pushing down with around 20lbs of tension.
Any advice is hugely welcome!
Thank you
This is the part:
Thank you
