I am using forteweb to analyze a multi span LVL basement beam. The beam is a drop beam and is pocketed into the foundation walls at each end. The center support is a steel column. Forte has an input for bottom edge lateral bracing. I am assuming there would be no lateral support at the bottom edge of the beam at the center support? In other words, I cannot assume the column provides any lateral support for the bottom edge of the beam?
