GaTechTheron
In a vertical turbine pump (VS1), I'm trying to calculate the minimum speed that we can operate the pump. Is there a way I can calculate the minimum speed required to properly lubricate the lineshaft bearings? Is this a function of fluid speed in column, or some sort of pressure drop?
I appreciate the help!
Thanks,
Theron
Thanks,
Theron
