nucleareng78
We are installing a Pall lube oil purification skid that will remove particulates, free water, and dissolved water. Each tank is around 600 gallons and our skids will operate as kidney loops.
The existing system uses a filtration skid (only some free water removal) and a oil cooler that uses a fan to cool it down. Question is, since it's simply a kidney loop, is it necessary to have an oil cooler? The new skid has a built in heater that can be set to kick in when needed. The whole skid will shut down when the temperature of the oil gets too high. Flow rate is around 5 gpm.
Just wanted some operating experience regarding using these type of air oil coolers.
