LU decomposition
hoshang
IQ
Hi all,
I wonder why LU for this matrix retrieves such LU decomposition result.
M=
-0.5 -1 0
-1 -1 -1
0 -1 -0.5
L=
1 0 0
0 1 0
0.5 0.5 1
U=
-1 -1 -1
0 -1 -0.5
0 0 0.75
While it should be:
L=
1 0 0
2 1 0
0 -1 1
I suggest you use a screenshot, smiley emoticons don't help.
Here's some Octave
>> M=[.5,-1,0;-1,-1,-1;0,-1,0.5]
M =
0.5000 -1.0000 0
-1.0000 -1.0000 -1.0000
0 -1.0000 0.5000
>> [L,U]=lu(M)
L =
-0.5000 1.0000 0
1.0000 0 0
0 0.6667 1.0000
U =
0 -1.5000 -0.5000
0 0 0.8333
>> M=[-.5,-1,0;-1,-1,-1;0,-1,0.5]
M =
-0.5000 -1.0000 0
0 -1.0000 0.5000
>> [L,U]=lu(M)
L =
0.5000 0.5000 1.0000
1.0000 0 0
0 1.0000 0
U =
0 -1.0000 0.5000
0 0 0.2500
>> M=[1.5,-1,0;-1,-1,-1;0,-1,0.5]
M =
1.5000 -1.0000 0
0 -1.0000 0.5000
>> [L,U]=lu(M)
L =
1.0000 0 0
-0.6667 1.0000 0
0 0.6000 1.0000
U =
1.5000 -1.0000 0
0 -1.6667 -1.0000
0 0 1.1000
Cheers
Greg Locock
Hi GregLocock,
thanks for your response. None of M matrix in your examples correspond to M in my example. Please try the M matrix in my example.
>> M=[-.5,-1,0;-1,-1,-1;0,-1,-0.5]
M =
-0.5000 -1.0000 0
0 -1.0000 -0.5000
>> [L,U]=lu(M)
L =
1.0000 0 0
0 1.0000 0
U =
0 -1.0000 -0.5000
0 0 0.7500
Which is a very strange result, L is not triangular. Sorry I don't know enough about lu to explain what that means.
Cheers
Greg Locock
Using the Scipy.Linalg LU function via Excel:
If I set permute_I to false I get the same as hoshang:
Lower =
1 0 0
-0 1 0
0.5 0.5 1
Upper =
-1 -1 -1
0 -1 -0.5
0 0 0.75
If I set permute_I to true I get the same as greg:
Permuted Lower =
0.5 0.5 1
1 0 0
-0 1 0
Upper =
-1 -1 -1
0 -1 -0.5
0 0 0.75
So greg's results give the permuted lower matrix. I'd have to remind myself of how these things work to know what you do with that.
Where did the values:
L=
1 0 0
2 1 0
0 -1 1
come from?
Doug Jenkins
Interactive Design Services
The results from Mathcad 14 are the same, and the extracted L, U, and P matrices behave as expected with P*M = L*U
TTFN (ta ta for now)
L=
1 0 0
2 1 0
0 -1 1
come from?
Thanks. Review any textbooks on LU decomposition. You will find out that the decomposition would be
L=
1 0 0
2 1 0
0 -1 1
U=
-0.5 -1 0
0 1 -1
0 0 -1.5
OK, so Mathcad's LU decomposition is a general purpose decomposition, see
The function assumes that a permutation matrix P is required to make the decomposition work; this is why the lu() function returns 3 matrices.
OK, so it seems the answer to the question:
is that there is more than one way to decompose a matrix.
It seems that Scipy and Octave are using a pivotted lower matrix, so that for an original matrix A:
PLU = A
whereas for hoshang's matrices:
LU = A
Excel screen shot, calling Scipy fumctions:
Apparently Mathcad is doing something different, but I don't have Mathcad to see what is going on there.
Doug Jenkins
Mathcad is doing P*M = L*U, and the link I posted indicates that when LU decomposition is possible, there may be multiple solutions, and P in Mathcad's case is the inverse of the P in Doug's example, as can be seen below
Hi all
So, how one can get hoshang results using Mathcad?
This link has a good detailed description of the procedures for forming and solving LU matrices, with and without pivoting:
It has python code for each stage of the process.
At the moment I'm having trouble getting their lu_decomp function to work. If anyone get's it working, please let me know.
Doug Jenkins
I have now got their code working. In the lu_decomp function:
Replace the two lines using np.block as below:
Python:
    # L = np.block([[L11, L12], [L21, L22]])
    # U = np.block([[U11, U12], [U21, U22]])
    L = np.zeros((n,n))
    U = np.zeros((n,n))
    L[0,0] = L11
    L[0,1:] = L12
    L[1:,0] = L21
    L[1:,1:] = L22
    U[0,0] = U11
    U[0,1:] = U12
    U[1:,0] = U21
    U[1:,1:] = U22
    return (L, U)
Also in the forward_sub function, replace:
for j in range(i-1):
with
for j in range(i):
With those changes the functions I tried seem to work correctly:
forward_sub
back_sub
lu_solve
lu_decomp
I haven't yet tried the functions using pivoting (but I'm working on it).
Doug Jenkins
What about my concerns?
Your original post has one questioned that has been answered in detail.
If you have remaining concerns perhaps you might tell us what they are.
Doug Jenkins
Similar threads
Replies
4
Views
339
