G'day all. I am a first time user here, so my questions may be a bit disjointed but will get to the point at the end.
My questions are;
Do lpg injectors exist that inject lpg in liquid form instead of atmo. pressure?
Is there a constant relationship between petroleum and lpg in characteristics?
Is it possible to set an aftermarket computer (Motech etc.) to convert the value of petrol to lpg in a petrol to lpg conversion?
eg. If you take any ordinary multipoint injection car and replace the standard injectors with lpg injectors. Then take the "wires" from the cars computer that go to the injectors and plug them into a new computer that is programmed to "convert" the information into new information for the new injectors. Therefore the cars original computer is thinking it is still doing what it always does. Also the mapping that the big car companies spend millions of dollars on is not going to waste. All the new computer does is convert the "pulse width" ( for lack of better term) for the new injector.
This is just a concept. Or is it not that simple.
Confused...
My questions are;
Confused...
