At a fixed field strength (direct current magnitude), torque is proportional to quadrature current, regardless of speed. Above base speed, the direct current magnitude is reduced to weaken the field in order to keep the back EMF down, but now more quadrature current is needed to produce the same amount of torque. (If the direct current is cut in half, twice the quadrature current is required to produce the same amount of torque.)
The total current magnitude is the vector sum of the orthogonal direct and quadrature currents. I suppose that for very low torque levels, the reduction in direct current can more than compensate for the required increase in quadrature current. But given that the direct current below base speed is only about 10-15% of the maximum quadrature current, the torque levels required for this to happen would have to be very low indeed.
Curt Wilson
Delta Tau Data Systems
