Low temperature ASME VIII
vittorio6
Materials
IT
I would appreciate your help on ASME VIII Div 1:
The scenario is: Carbon steel vessel with thickness of 60 mm and a minimum T of - 70°C during depressurization. Based on ASME VIII Div 1 UCS-66 is possible an exemption of impact test because the stress ratio is lower than 0.35.
Is the exemption applicable also to the weld metal?
Thanks in advance
V.
Is this stress ratio based on vessel at MAWP ( without taking credit for corrosion allowance) or depressurisation final pressure?
