I am working on a project and I am having difficulty finding structural steel to be used on the job. The final location for the heater is in Siberia and the customer has asked that we use low temp carbon steel and that all steel be rated for -56degreesF. Currently we are purchasing structural shapes of A572 GR50 and having them heat treated and some of the steel is still failing our Charpy Impact Test requirements. We cannot afford to keep purchasing material and simply hoping that it passes. I have found other grades such as A203, A537, A533 that would seem to work fine but I cannot find a steel distributor in the U.S. that has structural shapes of these grades. I am currently looking into A588 as I was told it is very similar to A572 but has a better history of passing impact test and is readily available.
Currently we are purchasing A572, sending it to be heat treated, and sending a sample of the heat treated material to a test facility to be impact tested. For example we call out 10" x 25# channel to be tested at -56F with three test specimens to meet an average of 15ft-lbs, with no one test below 10 ft-lbs, and no two tests below the average. The 10" channel failed to meet those requirements but 6" x 8.2# channel of the same material passed. According to our steel supplier, once the steel has been heat treated we have purchased it, pass or fail. I need a grade of steel that is available in structural shapes and will consistently pass these requirements. If anyone could please offer any insight or alternative material it would be greatly appreciated. Thank you! -Dakers
