How the machines lubricated and cooled? Are they slide valve machines or does their capacity reduction take another form? Do they have external lubricant cooling or?? Are they hermetics, semi hermetics or open drives? If they are hermetics or semi hermetics, measuring their real performance can involve a lot of instrumentation...If they are open drives, its a lot less instrumentation; and if they are water cooled on both the condensing and the oil cooling: the instrumentation and test get easier....But fundamentally, you make a COP and isentropic efficiency measurement with respect to the Manufacturer's original data which will lead to how badly are they worn?
Screw compressors can tolerate some pretty substantial deviation from the ideal: But to get them highly efficient you want to operate them at 100% load with just enough oil injection to keep them cool and to preclude internal bypassing....Of course, if they are taking liquid refrigerant from time to time, their oil separation, interlobe sealing and so on will suffer a lot.
